ISO-certified cylinders
C85 stainless steel cylinders
C85 stainless steel cylinders conform to ISO mounting dimensions. Meet ISO 6432 and offer corrosion-resistant anodized covers, abrasionresistant seals, and leak-proof assembly between covers and cylinder tube. Available as doubleacting, single rod; doubleacting, double rod; singleacting, spring return; and singleacting, spring extend. Designed for bores of 8 to 25 mm with strokes of 10 to 300 mm and speeds to 1500 mm/sec.
SMC Corp. of America, (317) 899-4650, www.smcusa.com
