Interchangeable cylinders
Accu A Series is a NFPA Interchangeable cylinder containing an internal linear resistive transducer. Conducive where variations in cylinder stroke and speed are required or when continuous position monitoring necessary. Available in eight bore ...
Accu A Series is a NFPA Interchangeable cylinder containing an internal linear resistive transducer. Conducive where variations in cylinder stroke and speed are required or when continuous position monitoring necessary. Available in eight bore sizes 1 1 /2 to 8 in.
Numatics Inc.,
(248) 887-4111,
www.numatics.com
