Cylinder brakes
The Dynamic Rod Lock is a braking and holding device for pneumatic cylinders and guid rods. Offers the ability to slow and stop loads in all axes without solely relying on the cylinder. Can be used as a standalone device or with ISO/NFPA ...
The Dynamic Rod Lock is a braking and holding device for pneumatic cylinders and guid rods. Offers the ability to slow and stop loads in all axes without solely relying on the cylinder. Can be used as a standalone device or with ISO/NFPA cylinders.
Spring-engaged brake actuation, air released. High clamping/holding force using a large clamp-to-rod surface area. Fits standard cylinder rod diameters 16, 20, 25, and 32 mm and 0.625, 1, and 1.375 in.
Nexen Group Inc.
(651) 484-5900
www.nexengroup.com
