Lightweight cylinders
Non-metallic pneumatic actuators combine high-strength composites with plastics such as Delrin, ABS, or UHMWPE, for use in corrosive environments. Tube is lightweight and has a smooth bore finish for long seal life and lubrication retention. Glass-filled composite guide rod provides high load carrying capabilities and provides low breakaway forces and reduced weight when coupled with a Polylube Guide Rod bearing. They withstand working pressures to 125 psi.
Polygon Co.
(800) 918-9261
www.polygoncomposites.com
