Pneumatic Cylinders
RTC rodless thrust cylinders offer high load capacity. Four versions are available. RTC-BV (basic version) is suitable for universal use, while RTC-CG (compact guide) offers high precision in compact dimensions. RTC-EG (e-line guide) is a guided ...
RTC rodless thrust cylinders offer high load capacity. Four versions are available. RTC-BV (basic version) is suitable for universal use, while RTC-CG (compact guide) offers high precision in compact dimensions. RTC-EG (e-line guide) is a guided version and RTC-HD (heavy duty) handles heavy loads. They are available in diameters from 16 to 80 mm and maximum stroke length of 9900 mm. Working pressure is 30 to 120 psi
Bosch Rexroth Corp.
(859) 259-3852 www.boschrexroth-us.com/pneumatics
