Low-profile cylinders
RC series locking collar low-profile cylinders lift heavy loads when other cylinders will not fit. They are single-acting, load-return cylinders with 55 to 620 ton capacity. Locking collar supports lifted load for extended periods when hydraulic ...
April 30, 2007
RC series locking collar low-profile cylinders lift heavy loads when other cylinders will not fit. They are single-acting, load-return cylinders with 55 to 620 ton capacity. Locking collar supports lifted load for extended periods when hydraulic pressure is released. They come with integral tilt saddle for side loads, 3⁄8 in. NPT female half couplers, and overflow port or weep hole to prevent piston from being overextended under load.
Power Team, (800) 541-1418, www.powerteam.com
