Reed Sensors
Series 8000 compact reed and electronic sensors fit round cylinders from 916 to 4 in. and tie-rod cylinders from ¾ to 8 in. bore. They are compatible with wash down applications and intrinsically safe barriers and have encapsulated circuit ...
They are compatible with wash down applications and intrinsically safe barriers and have encapsulated circuit and operational temperature range of –20° to 80°C. Reed versions offer voltage from 0-120 Vac/Vdc Hz and current capacity to 0.5 A. Electronic versions offer voltage from 6-24 Vdc and current capacity of 0.3 A.
Canfield Connector, (330) 758-8299
www.canfieldconnector.com
