Compact sensor is well-suited to off-highway equipment
MH linear-displacement transducer combines reliable in-cylnder mounting with a CANbus to serve the needs of the latest mobile equipment. MTS Systems Corp., Sensors Div., Cary, N.C., recently introduced ...
MTS Systems Corp., Sensors Div., Cary, N.C., recently introduced its MH linear displacement transducer (LDT) with a CANbus interface. Combining proven Temposonics mangetostrictive technology with the off-road market’s interface of choice, the compact sensor is intended for use in welded and tie-rod cylinders, or any space-limited cylinder applications.
The MH sensor works with CAN J1939 and CANopen, measuring displacement and speed variables. The LDT mounts inside a hydraulic cylinder, and a recent redesign of the mechanical housing has provided a more robust wire-cable exit that improves strain relief and sealing. With a 100-G shock and 25-G vibration rating, the MH sensor was designed for rugged environments, especially those typically encountered in construction, agriculture, and other off-highway equipment.
The LDT consists of a sensor head, a housing with built-in electronics, a pressure-proof sensor pipe that protects an internal sensing element, and a position magnet. Along with high shock and vibration ratings, the sensor has 200V/m EMI protection.
Designed for cylinders with a bore of 2 in. or larger to measure strokes from 2 to 98 in. (50-2500 mm). M-Series sensors meet ISO14982 standards for agricultural and forest machines, ISO7637- 0/1/2 standards for road vehicles, and are CE-certified. The LDT can be installed from the cylinder’s head or cap end.
For more information, call Brian Cox at (919) 677-2355, e-mail brian.cox@ mts.com, or visit www.mts.com.
