Pressure gauge
Type 1009 Duralife stainless-steel pressure gauge is now available with a ¼-in. or 6-mm OD tubing connection. Threadless, straight tube design allows it to be directly connected to pressure tubing systems via standard ferrule type mechanical grip couplings. Connection eliminates need for adapters and facilitates quick installation and removal. Optional tubing connection is offered on 2½ and 3½ in. type 1009 gauges with full scale ranges to 7500 psi.
Ashcroft Inc., (203) 378-8281, www.ashcroft.com
