Pressure measurement instrumentation
Heise precision pressure instruments provide the high accuracy measurements required for critical test, calibration and process applications.
Heise precision pressure instruments provide the high accuracy measurements required for critical test, calibration and process applications. Configurations include the Heise 0.1% precision dial pressure gauge, which is available in three models; the modular PTE-1 handheld calibrator and high accuracy digital pressure indicators, which are offered in ranges of gauge, differential, compound, vacuum and absolute; and two models of transducers, which also are offered in ranges of gauge, differential, compound, vacuum and absolute. With ranges from 0.25 in. H2O to 100,000 psi and accuracies to ±0.025% FS, Heise precision instruments provide reliable, precise readings when measurement certainty is imperative.
Ashcroft Inc., (800) 328-8258, www.heise.com
