Pressure transmitters
ProSense IP68/IP69K-rated 5000 psi pressure transmitters are available in 0 to 10 V and 4 to 20 mA output models. They are designed to monitor relative system pressure in multiple applications and offer a solution to mechanical pressure switches.
ProSense IP68/IP69K-rated 5000 psi pressure transmitters are available in 0 to 10 V and 4 to 20 mA output models. They are designed to monitor relative system pressure in multiple applications and offer a solution to mechanical pressure switches. A ceramic sensing element provides high burst/ overpressure protection. Flexible film circuitry allows for mounting to flexible film, which can then be placed in stainless steal housing. The operating temperature ranges from –13° to 176º F (–25º to 80º C).
AutomationDirect, (770) 889-2858, www.automationdirect.com
