Magnetic proximity sensor
The 7HL magnetic proximity sensor is designed to sense actuator position in hazardous locations. Floating clamp ensures assembly and sensor position on 2 to 8-in. bore NFPA tie rod cylinders. It switches current to 0.5 A at 0 to 120 Vac/Vdc ...
The 7HL magnetic proximity sensor is designed to sense actuator position in hazardous locations. Floating clamp ensures assembly and sensor position on 2 to 8-in. bore NFPA tie rod cylinders. It switches current to 0.5 A at 0 to 120 Vac/Vdc 50/60 Hz. It also features an aluminum body, epoxy encapsulated circuit board PCB, and 1/2 in. conduit female thread with hard-usage multiconductor cable.
Canfield Connector, (330) 758-8299, www.canfieldconnector.com
