Pressure gauges
Ashcroft type 1259
Ashcroft type 1259 pressure gauges available with ASME B40.100 Grade 2A accuracy of ±0.5% full scale. Features 41/2 in. solid front safety case, 316 stainless steel or Monel wetted parts, and ranges from vacuum to 20,000 psi. Duratube Bourdon tube, 300 stainless steel movement, and in-field liquid fill capability eliminate need for dedicated fill kit.
Dresser Instruments, (203) 378-8281, www.ashcroft.com
