Cable-Extension Transducers
SR1A-125 cable-extension transducers provide position feedback in wet and outdoor environments. They have a 500K OHM pot or voltage divider output and offer 125-in. measurement range. Mounting bracket provides multiple cable exit direction ...
SR1A-125 cable-extension transducers provide position feedback in wet and outdoor environments. They have a 500K OHM pot or voltage divider output and offer 125-in. measurement range. Mounting bracket provides multiple cable exit direction options, allowing for mounting to any vertical or horizontal service. Constant tension, fully retractable stainless-steel measuring cable wraps around internal spring-loaded spool coupled to a precision sensor. Spool’s movement produces a voltage directly proportional to the position of the measuring cable.
Celesco Transducer Products Inc., (800) 423-5483, www.celesco.com
