Pressure transducers
The 3100 and 3200 pressure transducers are constructed of stainless steel, measure less than 1 in. in diameter, and weigh just 32 g. Pressure sensing ranges span 0 to 30,000 psi, with various outputs and pressure ports, and high shock and vibration ...
The 3100 and 3200 pressure transducers are constructed of stainless steel, measure less than 1 in. in diameter, and weigh just 32 g. Pressure sensing ranges span 0 to 30,000 psi, with various outputs and pressure ports, and high shock and vibration resistance. They deliver an output signal for temperature and pressure, providing full-scale accuracy of 0.25%, and long term drift limited to 0.1% over the full scale per year. Models include voltage, current, or ratiometric output versions.
Gems Sensors & Controls, (800) 378-1600, www.gemssensors.com
