Proportional drivers
Series 5950 and B5950 micro proportional drivers accurately control hydraulic and pneumatic solenoid valves. Fluid flow can be linearly controlled at a setting from 0.010 to 20 sec. They allow a solenoid to oscillate, reducing shock and wear. ...
Series 5950 and B5950 micro proportional drivers accurately control hydraulic and pneumatic solenoid valves. Fluid flow can be linearly controlled at a setting from 0.010 to 20 sec. They allow a solenoid to oscillate, reducing shock and wear. 5950 incorporates male and female DIN Form A interfaces and features a compact electronic circuit in NEMA-4 enclosure. B5950 features an epoxy-potted enclosure with top surface adjustments and on-board diagnostics. Canfield Connector, (330) 758-8299, www.canfieldconnector.com
