Industrial pressure transmitter
Edited By Mary C. Gannon WIKA Tronic A-10 pressure transmitter is resistant to vibration, shock, wide temperature variations, RFI, and other extreme environmental conditions. It is suited for applications where negative pressures are measured. It ...
WIKA Tronic A-10 pressure transmitter is resistant to vibration, shock, wide temperature variations, RFI, and other extreme environmental conditions. It is suited for applications where negative pressures are measured. It operates in pressure ranges from 0 to15 psi to 0 to 10,000 psi. Signal output is 4-20 mA, 0-10 V, or 0-5 V. Electrical connections include DIN 175301-803 A and C, M12x1, and 6 ft cable. Pressure connection is via 14 NPT, 12 NPT, SAE #4, or others.
WIKA Instrument Corp., (888) 945-2872, www.wika.com
