Displacement sensors
D-series sensors use Temposonics magnetostrictive technology and have a measuring range from 50 to 1500 mm and direct position output from 0 to 10 V. They offer linearity better than 0.01%, repeatability of 0.005%, and position update rate of ...
D-series sensors use Temposonics magnetostrictive technology and have a measuring range from 50 to 1500 mm and direct position output from 0 to 10 V. They offer linearity better than 0.01%, repeatability of 0.005%, and position update rate of 1.5 kHz, while eliminating noise, wear, and signal problems. Waveguide sensing element, conditioning electronics for output position data, and IP 67 housing come standard.
MTS Systems Corp., Sensors Div., (919) 677-2314, www.mtssensors.com
