Gauges with digital display
Gauges with digital display DG-10 Digital Display gauge is ideal for applications requiring a local, AA battery-operated measurement and display instrument. They feature a stainless steel housing and are available in two versions: standard ...
DG-10 Digital Display gauge is ideal for applications requiring a local, AA battery-operated measurement and display instrument. They feature a stainless steel housing and are available in two versions: standard (DG-10-S) and enhanced (DG-10-E). Both include a multifunction LCD-display with a bar graph featuring a drag pointer function and a MIN/ MAX memory. Both allow the user to easily switch between measurement units including bar, psi and MPa.
WIKA Instrument Corp., (888) 945-2872, www.wika.com
