Cartridge-style flow regulators
JP02C two-port proportional flow regulators provide precise electrical control of hydraulic fluid flow at pressures to 210 bar. Pressurecompensated spool-type solenoid valves deliver a regulated flow proportional to the input solenoid ...
JP02C two-port proportional flow regulators provide precise electrical control of hydraulic fluid flow at pressures to 210 bar. Pressurecompensated spool-type solenoid valves deliver a regulated flow proportional to the input solenoid current. They operate independent of fluctuations in the load or changes to input. A normally open version (JP02P) is also available. Three models handle flows to 7.5, 15, and 23 lpm. Each can be fitted with 12 or 24-Vdc solenoids.
Sterling Hydraulics Inc., (847) 690-1333, www.sterling-hyd.com
