Dynamic pressure sensors
Series 102M dynamic, ICP pressure sensors are certified under ATEX and CSA as intrinsically safe for hazardous environments. They monitor compressor, pump, and gas turbine performance by measuring surges, pulsations, and spikes. They also detect ...
Series 102M dynamic, ICP pressure sensors are certified under ATEX and CSA as intrinsically safe for hazardous environments. They monitor compressor, pump, and gas turbine performance by measuring surges, pulsations, and spikes. They also detect flow anomalies in piping systems. They are rated for pressures to 20,000 psi with sensitivity to 300 mV/psi.
PCB Piezotronics Inc., Pressure Div.,(888) 684-0011, www.pcb.com
