Ultrasonic transducer
Dynasonics DTTS transducer installs easily on 1/2 to 2 in. pipe and rigid tubing. If used with time transmitter, it replaces mechanical flow meters. There is no contact with internal liquid or moving parts. It is used with clean liquids or those ...
Dynasonics DTTS transducer installs easily on 1/2 to 2 in. pipe and rigid tubing. If used with time transmitter, it replaces mechanical flow meters. There is no contact with internal liquid or moving parts. It is used with clean liquids or those with moderate amounts of suspended solids or aeration, and on carbon and stainless steel, copper, and plastic pipe materials.
Racine Federated Inc., (800) 535-3569,
www.dynasonics.com
