Temperature switches
ETS 3000 electronic temperature switches come as stand-alone units with separate temperature probes or as pressure resistant types with integrated probe. Pressure resistant types measure from 75° to 210°F; probe types measure from –20° to 300°F. They are ...
ETS 3000 electronic temperature switches come as stand-alone units with separate temperature probes or as pressure resistant types with integrated probe. Pressure resistant types measure from 75° to 210°F; probe types measure from –20° to 300°F. They are rated to 8700 psi, mount directly into pipes or manifolds, and have one or two switching transistor outputs and optional analog output. Maximum switching capacities are 1.2 A for connection of PLC input cards and direct connection of standard solenoid control valves.
HYDAC Technology Corp. - Electronic Div., (877) 464-9322, www.hydacusa.com
