Pressure transducers
Schaevitz pressure transducers provide maximum resolution at required measured pressure range. They feature bonded foil strange gauge technology and Over Travel Stop overload protection for the diaphragm, which allows sensing element to handle ...
Schaevitz pressure transducers provide maximum resolution at required measured pressure range. They feature bonded foil strange gauge technology and Over Travel Stop overload protection for the diaphragm, which allows sensing element to handle minimum of five-times full-scale over-range pressure spikes without damage or drift. They are rated for pressures from 0-75 to 10,000 psi with accuracy to ±0.08%.
Measurement Specialties Inc., (610) 971-9893, www.meas-spec.com
