Digital pressure gauges
HPM110 pressure gauges are designed for continuous or test monitoring of hydraulic, pneumatic, oil, water, and other pressure media. Simple digital display monitors working pressure and damaging pressure spikes. Hand-held unit can be installed ...
HPM110 pressure gauges are designed for continuous or test monitoring of hydraulic, pneumatic, oil, water, and other pressure media. Simple digital display monitors working pressure and damaging pressure spikes. Hand-held unit can be installed using a standard test point or left permanently connected to the system. They are available in 1500 and 8700 psi models and simultaneously display actual pressure, peak pressure, battery level, and engineering units.
Webster Instruments, (414) 769-6400, www.webster-inst.com
Circle 153
