Electronic proportional regulator
P3HP pressure regulator quickly and accurately adjusts and maintains set output pressure regardless of flow in response to an electronic control signal. It eliminates inconsistencies caused by time, cycling, input, backpressure, or pressure and ...
P3HP pressure regulator quickly and accurately adjusts and maintains set output pressure regardless of flow in response to an electronic control signal. It eliminates inconsistencies caused by time, cycling, input, backpressure, or pressure and flow variations. Control signal options are configurable to accept 0 to10 V or 4 to 20 mA.
Parker Hannifin Corp., Pneumatic Div., (269) 629-5000, www.parker.com/pneumatic
