Testing, maintenance system
ET-100 electronic sensor and EasyTest fittings test, troubleshoot, and perform preventative maintenance, while operating safely at pressures to 6000 psi. Large meters feature easyto- read scales. Load control knob and scale selector switches are easy to grasp. Sensor and fitting are the only components that come in contact with fluid, so cleanup is limited to draining the sensor and replacing the fitting’s cap.
Schroeder Industries
 (724)318-1100
 www.schroederindustries.com
