Compact instrument packs multiple features
Serviceman Plus is a portable and easy-to-use instrument that measures pressure, flow, speed, and temperature in mobile and industrial hydraulic systems. Data can be saved to a removable USB stick or transferred through its USB interface to a PC for further analysis. With a sampling rate of 1 msec, Serviceman Plus is available in two versions: with two inputs for analog sensors or with a CAN interface for up to three CAN sensors.Features include automatic sensor recognition, 62-mm-square backlit display of minimum, maximum, and differential measurements, internal
memory expandable to 1 Gbyte via USB stick (provided), IP67 protection rating, and rear panel integrated support for free-standing operation.
Analog version has measurement error of ±0.02% ±one digit, 5-pol, push-pull plug connection, and is compatible with all SensoControl analog type sensors and accessories. CAN version has 5-pol, M12×1, Speedcon plug connection, and is compatible with all SensoControl CAN type sensors and accessories.
For more information, call Parker Hannifin’s Quick Coupling Div., Minneapolis, at (763) 525-7781 or visit www.parker.com/quickcouplings
Related
Sponsored
