Large manifolds
Manifolds are available in ductile iron, aluminum, and steel in sizes from 2000 to 4000 lb. The block size capacity is 40 40 67 in. Tooling to machine is available up to 100 mm DIN cavities. They are manufactured on one machine, allowing raw material and final product to go out in one operation, which minimizes errors.
Daman Products Co., (800) 959-7841, www.damanifolds.com
