Variable displacement pump
Type V30E-270 variable displacement axial-piston pump features a redesigned housing and a mounting flange SAE E which conforms to the standard SAE J744. It has an operating pressure of up to 5075 psi (350 bar), with a peak pressure of 6000 psi (420 bar).
Output volume is up to a maximum of 124 gpm (470 lpm) at 1.750 rpm, with a geometric displacement of 270 cm3/rev.
HAWE North America Inc.
(704) 509-1599
http://bit.ly/HP1011HAWE
