Piston pumps
Fixed-displacement piston pumps include P, Q, R, Rtandem, T Series, are birotational, in-line design offering a variety of displacements. T-Series is bent axis style, can be operated as either a pump or motor. All models are equipped with the ...
Fixed-displacement piston pumps include P, Q, R, Rtandem, T Series, are birotational, in-line design offering a variety of displacements. T-Series is bent axis style, can be operated as either a pump or motor. All models are equipped with the DIN 5462 mounting to handle high loads and reduce fretting. Displacements range from 0.732 in. 3 to 6.1 in.3, pressures to 5075 psi continuous, and speeds to 2400 rpm. All pumps are covered by a oneyear warranty.
Muncie Power Products Inc.,
(800) 428-8590,
www.munciepower.com
