Adaptor provides extra shaft support
Overhung load adaptors (OHLA) provide load support to eliminate premature hydraulic motor or pump bearing failure. They provide a solid mounting surface while sealing out dirt and contamination. Designed for face or foot mounting, they come with many ...
Overhung load adaptors (OHLA) provide load support to eliminate premature hydraulic motor or pump bearing failure. They provide a solid mounting surface while sealing out dirt and contamination. Designed for face or foot mounting, they come with many shaft options including splined, threaded, tapered and extended output shafts. More than 50 standard models are available for handling axial and radial overhung loads. Input bore sizes range from 58 to 312 in.; available SAE mounts include A, B, C, D, E, and F with 2- or 4-bolt mounting flanges.
Zero-Max, Plymouth, Minn., at (800) 533-1731, or visit www.zero-max.com.
