Air-driven pumps
IDI pumps operate in pressures from 100 to 10,000 psi from 60-psi air. Rated for flows to 6 gpm and have built-in air regulator. E, H, and P series come with optional integrated hydraulic circuitry for cylinder actuation and pressure ...
March 20, 2007
IDI pumps operate in pressures from 100 to 10,000 psi from 60-psi air. Rated for flows to 6 gpm and have built-in air regulator. E, H, and P series come with optional integrated hydraulic circuitry for cylinder actuation and pressure sensing. Available in doubleacting and multi-ratio configurations. Single-acting TASQ models comes with a NFPA DO3 valve pad.
Interface Devices Inc., (800) 539-0885, www.interfacedevices.com
