In-line hydraulic filter
HRK10 low-pressure, high-flow filter features all-steel construction, Synteq filter media, and multi-valve bypass design. Twist and lift cover eliminates need to remove bolts, reducing time and cost of service. Filter attaches to bypass assembly ...
HRK10 low-pressure, high-flow filter features all-steel construction, Synteq filter media, and multi-valve bypass design. Twist and lift cover eliminates need to remove bolts, reducing time and cost of service. Filter attaches to bypass assembly with finger-activated clip, for element removal. Standard fluorcarbon seals make it compatible with many hydraulic fluids. A visual service indicator is standard; electrical service indicator optional. Element choices have media efficieny ratings from 4 to 25 µm at ß=1000.
Donaldson Co., (952) 887-3863, www.donaldson.com
