Reservoir breathers
H20-Gate, Dirt-Gate, and mobile gate reservoir breathers use proprietary media to block water vapor from entering the reservoir. Indicator actuates when particles block media, before pump cavitates. Reduce dew point temperature to prevent ...
H20-Gate, Dirt-Gate, and mobile gate reservoir breathers use proprietary media to block water vapor from entering the reservoir. Indicator actuates when particles block media, before pump cavitates. Reduce dew point temperature to prevent condensation and 99.7% efficient in blocking particles 3 µm and larger. Reversible flow through media allows moisture to exit reservoir.
Eaton Hydraulics
(952) 937-9800
www.hydraulics.eaton.com
