Self-contained offline filter
Self-contained offline filter system removes large amounts of contamination through single pass technology. Synthetic membrane technology in the shape of discs allows filter elements to remove more than 1 lb of contamination. Filtration ...
Self-contained offline filter system removes large amounts of contamination through single pass technology. Synthetic membrane technology in the shape of discs allows filter elements to remove more than 1 lb of contamination. Filtration available as low as 2 µm with flow rates to 20 gpm.
Hydac Technology Corp., Hycon Div.
(877) 464-9322
www.hydacusa.com
