Pressure filters
Compo Care pressure filters are available in seven models — high (6000 psi) and medium pressure (3000 psi) units and models with NFPA interface and manifold mounting. They are rated for flows to 160 gpm with media from 140 µm wire mesh to 3 µm ...
Compo Care pressure filters are available in seven models — high (6000 psi) and medium pressure (3000 psi) units and models with NFPA interface and manifold mounting. They are rated for flows to 160 gpm with media from 140 µm wire mesh to 3 µm fiberglass with a ß>200. Universal Hydraulics International Ltd., UFI Filters Div., (330) 405-1800, www.uhiltd.com
