Return-line filters
Return-line filters RIF300 series return line filters for inline hydraulic applications provide an effective and efficient solution for contamination removal. They are rated for flows to 1135 lpm and maximum pressures to 34.5 bar (maximum burst ...
Return-line filters
RIF300 series return line filters for inline hydraulic applications provide an effective and efficient solution for contamination removal. They are rated for flows to 1135 lpm and maximum pressures to 34.5 bar (maximum burst pressure of 103 bar). They operate in temperatures from -29 ° to 107° C. Bypass valve allows unfiltered oil to bypass the contaminated element once the opening pressure has been reached.
Stauff Corp.,
(201) 444-7800,
www.stauffusa.com
