Wire-braided hose
M3KH and M4KH
M3KH and M4KH wire braid hoses are rated 3000 and 4000 psi, respectively, at 250°F and recommended for mobile equipment with small reservoirs, high velocity, high pressure fluids, and short hose lengths. The hoses have small outside diameter for tight bend radii and high flexibility for easy hose routing.
Gates Corp., (303) 744-5503, www.gates.com
