Protective hose covers
Pirtektor abrasion resistant cover for hydraulic hoses was tested to ISO6945, and showed a high level of abrasion resistance when compared against hoses made with both standard and specialized rubber coverings. They are ...
Pirtektor abrasion resistant cover for hydraulic hoses was tested to ISO6945, and showed a high level of abrasion resistance when compared against hoses made with both standard and specialized rubber coverings. They are available for hoses in the following sizes and pressure ratings: 1¼ in. rated to 3000 psi, 1 in. rated to 3600 psi, 1¼ in. rated to 4000 psi, 5/8 and 3/4 in. rated to 5000 psi, 3/4 in. rated to 6000 psi, and 1½ in. rated to 1250 psi.
Pirtek, (321) 504-4422, www.pirtekusa.com
