New 472LT and 722LT hoses work in temperatures from –70°F to 212°F (–57°C to 100°C). They are designed for high-impulse, applications. The 472LT is available in 1⁄4- to 1-in. sizes. No-skive, two-wire braided hose is rated for pressures to 5800 psi (40 MPa).
Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 05 Parker 472 Lt
New 472LT and 722LT hoses work in temperatures from –70°F to 212°F (–57°C to 100°C). They are designed for high-impulse, applications. The 472LT is available in 1⁄4- to 1-in. sizes. No-skive, two-wire braided hose is rated for pressures to 5800 psi (40 MPa). Rated up to 4000 psi (28 MPa), the no-skive, four-wire spiral 722LT is available in sizes from 3⁄8 to 2 in. Both use 43 series fittings; 722LT also uses 71 series. Both feature a half-bend radius.
