Modular aluminum piping
SmartPipe compressed air distribution system is made from aluminum with a low friction coefficient, to provide high flows without rust or corrosion. Full bore fittings minimize pressure drop and leak-free connectors prevent compressed air loss. ...
SmartPipe compressed air distribution system is made from aluminum with a low friction coefficient, to provide high flows without rust or corrosion. Full bore fittings minimize pressure drop and leak-free connectors prevent compressed air loss. Lightweight materials and push-to-fit connectors can be installed without threading, welding, or sweating. Sizes available for headers and branch lines to point of use.
Kaeser Compressors Inc., (800) 777-7873, www.kaeser.com/smartpipe
