UV-resistant cable wrap
Heli-Tube UVresistant black polyethylene spiral wrap is designed for bundling and protecting wires, cables, and hoses in harsh outdoor applications. Seven sizes from 1/8 to 11/2 in. OD. Easy to install, it eliminates need for heat-shrinkable ...
Heli-Tube UVresistant black polyethylene spiral wrap is designed for bundling and protecting wires, cables, and hoses in harsh outdoor applications. Seven sizes from 1/8 to 11/2 in. OD. Easy to install, it eliminates need for heat-shrinkable tubing and tape, dampens vibration, and resists abrasion. Unaffected by direct sunlight, saltwater, fuels, oils, and detergents, it operates over -105° to 215° F range, conforms to ASTM Taber D 1044 and meets federal specifications LP 390, MIL-I-631D, and MIL-P-26692.
M.M. Newman Corp.
(800) 777-6309
www.mmnewman.com
