Hydraulic hose
Edited by Mary C. Gannon PFMU21-20 hydraulic hose is designed to work at 3000 psi and has an abrasion resistant cover which is MSHA approved and conforms to SAE 1754B. It is available 114 in. bore size and has a bend radius of 1312 in. It is ...
PFMU21-20 hydraulic hose is designed to work at 3000 psi and has an abrasion resistant cover which is MSHA approved and conforms to SAE 1754B. It is available 114 in. bore size and has a bend radius of 1312 in. It is constructed with an oil resistant inner tube, a 4-wire spiral reinforcement, and is available in lengths of up to 131 ft.
Pirtek, (321) 504-4422, www.pirtekusa.com
