Fittings, tubingp
A line of metric and industrial fittings and tubing includes metric compression DIN2353, flared SAE J514, adapters BSI 5200, O-ring face seals, SAE J1453 fittings, and non-return valves. Metric carbon steel hydraulic tubes conform to DIN 2391 ...
A line of metric and industrial fittings and tubing includes metric compression DIN2353, flared SAE J514, adapters BSI 5200, O-ring face seals, SAE J1453 fittings, and non-return valves. Metric carbon steel hydraulic tubes conform to DIN 2391 and DIN 2445.
Stainlesssteel hydraulic fittings conform to ASTM A269. Steel tubes available with zinc-dichromate finish. Stainless tubes available with polished or unpolished finish.
World Wide Metric Inc.
(732) 237-2300
www.worldwidemetric.com
