Hot oil hose
Hot oil hose MegaTech LOC hydraulic hose is designed for high temperature (300° F continuous), low-pressure applications on mobile, and truck and bus equipment. Four sizes have working pressure ratings from 250 to 3000 psi. It meets or exceeds SAE ...
Hot oil hose
MegaTech LOC hydraulic hose is designed for high temperature (300° F continuous), low-pressure applications on mobile, and truck and bus equipment. Four sizes have working pressure ratings from 250 to 3000 psi. It meets or exceeds SAE J1019 specifications and accepts lock-on couplings and crimped couplings. Textile cover provides resistance to oil, heat, abrasion, and cracks.
Gates Corp.,
(303) 744-5503,
www.gates.com/fluidpower
