End-capped piston series
SK280 series piston accumulators utilize a patented end cap arrangement for decreased wall thickness. Sized 0.16 to 10 l, with an inner diameter of 40 to 125 mm. Pressure rating of 4000 psig. Available with gas charging valves and sealed gas ...
SK280 series piston accumulators utilize a patented end cap arrangement for decreased wall thickness. Sized 0.16 to 10 l, with an inner diameter of 40 to 125 mm. Pressure rating of 4000 psig. Available with gas charging valves and sealed gas ports. Built in accordance to Pressure Equipment Guidelines DGRL 97/23/EG.
Hydac Corp.,
(610) 266-0100,
www.hydacusa.com
