Motion transfer system
Rapid Advance & Retract Pneumatic Soft Touch System controls rapid cylinder travel while moving objects weighing up to 3000 lb. distances up to 15 ft at speeds to 5 ft/sec. Cylinder speed can be adjusted while cylinder is in motion. Decell ...
Rapid Advance & Retract Pneumatic Soft Touch System controls rapid cylinder travel while moving objects weighing up to 3000 lb. distances up to 15 ft at speeds to 5 ft/sec. Cylinder speed can be adjusted while cylinder is in motion. Decell mechanism engages for safety if power fails. All NFPA and metric cylinder mounting styles available.
Peninsular Cylinder Co., (586) 775-7211, www.peninsularcylinders.com
