Compact valves
SPECS Pressure: to 7,500 psi FEATURES Plug-and-play compatibility Reliable cartridge valves Solenoid-operated directional spool valves with split valve body Compensate for coaxial clearance; allow high tightening torques Bosch ...
FEATURES
  • Plug-and-play compatibility
  • Reliable cartridge valves
  • Solenoid-operated directional spool valves with split valve body
  • Compensate for coaxial clearance; allow high tightening torques
Bosch Rexroth
(610) 694-8298
www.boschrexroth-us.com
