Scissor Lift Achieves Perfect Heights
The new Titan Series A1050 Lift, from Herkules Equipment Corp., Walled Lake, Mich., is a 100% air-operated material handling scissor lift. The A1050 uses Herkules' Air Bag technology to provide a direct one-to-one lift ratio, eliminating the ...
The new Titan Series A1050 Lift, from Herkules Equipment Corp., Walled Lake, Mich., is a 100% air-operated material handling scissor lift. The A1050 uses Herkules' Air Bag technology to provide a direct one-to-one lift ratio, eliminating the need for mechanical linkage to lift the load — in turn minimizing wear and maintenance. The lifting motion is smooth and stable, and the heavy-duty air bags are built for rugged daily use.
The A1050 Lift is ideal for improving ergonomics and productivity by raising pallets or containers to the perfect height, from 7- to 29-in., so workers do not need to strain and bend while unloading or loading material.
The A1050 Lift comes in three models, with load capacities of 1000, 2000, and and 3000 lb.
For more information, contact Herkules at (800) 444-4351, email info@ herkules.us, or visit their website at www.herkules.us.
